Home > Maintenance & Mods (L322) > TDV8 3.6 noisy belt?
Hammer
Australia 2007 Range Rover Vogue TDV8 Zambezi Silver
My 2007 has developed an annoying squeaky belt sound which seems to be getting louder, I sprayed the fan belt with water and the noise temporarily went away.
I havnt seen any posts before describing this or if the belts require replacement at some interval mine has 250,000 kms. Just wondering if anyone has had the same, it could even be a noisy idler
Cheers Paul 2015 AB 5.0 Supercharged
2007 TDV8 Vogue
2000 P38, Gen3s, 2 inch lift, KM2s 285/75/16
Post #393587 29th Jun 2016 9:10am
FleXzoR
Belgium 2016 Range Rover Autobiography SDV8 Santorini Black
At 90k miles (150k km) i had also a noisy belt on my supercharged.
Replaced belt and all gone now.
Belt still looked good but was a bit 'glazed'. MY2008 Buckingham Blue Supercharged - gone
MY2016 Santorini Black 4.4 SDV8 LWB AB
Post #393604 29th Jun 2016 10:35am
mpirie
Check the 2 idler pulleys and tensioner pulley too. The bearings dry out and become noisy.
Quite cheap to buy and can easily be replaced once the belt is off.
Mike
Post #393611 29th Jun 2016 11:07am
jumbaleo
It could be the bearings on the Alternator on its way out. Might pay to check it at a garage, as exactly the same happened to me and I had to get recovered.
Post #394431 4th Jul 2016 4:15pm
Hammer
Thanks Guys,
I sprayed a little silicon on the belt and it seams to fixed as the squeal has since gone.
2007 TDV8 Vogue
Post #394768 6th Jul 2016 12:38pm
Clivefog
For now, get it changed soonest.
Post #394778 6th Jul 2016 1:41pm
