Home > Technical (L322) > Rear ride hieght sensor L322 td6 vogue 2005
Brydo
United Kingdom 2004 Range Rover Vogue Td6 Zermatt Silver
When using my All comms diagnostics tool to check air suspension levels the near nearside is giving a level of 0. Is there a problem with this ride height sensor. Any help will be most welcome. Confused
Post #393496 28th Jun 2016 7:03pm
Don't have an all comms so don't know, what do the others say..??
With the IID tool the readings from the four corners are all different, the EAS doesn't mind it just remembers where they should be, the sensor is a hall effect sensor so no two will be exactly the same...
If it sits level and that corner doesn't drop or raise away from the others then I expect it's OK... Thumbs Up Pete
Post #393501 28th Jun 2016 7:55pm
Brydo
the aii comms gives a value of between 8 and 5.8 for the other sensors but 0 for n/s rear. I can clear the fault code but when on uneven ground air suspension inactive returns. My rr sits higher at the rear than the front ( off road level.
Post #393676 29th Jun 2016 6:22pm
You didn't mention you had a fault showing...
Sounds like that's probably it then... Thumbs Up Pete
Post #393700 29th Jun 2016 7:48pm
Brydo
Thanks Pete. I'm new to rr so need all the help I can get Big Cry
Post #393712 29th Jun 2016 8:27pm
Read all the features in the WIKI , download Rave the workshop manual and put your anorack on.... Thumbs Up Pete
Post #393719 29th Jun 2016 8:45pm
