Home > LPG > Lpg eml valve saver issues
Skip720
England 2002 Range Rover HSE 4.4 V8 Oslo Blue
Hi guys, Iam new to range rovers and got a L322 4.4 V8 with a brc lpg kit on. I have just had the lpg overhauled and the eml has come on, using a icarsoft I have found that this relates to both banks running lean. I have bought a flashlube kit and was wondering if anybody else runs a similar kit because I have no idea where I would tee it in.
Thanks in advance
Post #393483 28th Jun 2016 6:17pm
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
I use the BRC system in a 2004 L322. When having it fitted, I was told it doesn't need a flashlube kit, nor have I ever had a EML come on.
The set-up of the systems are as important as the quality of the kit itself and I wonder if the person who overhauled it hasn't set it up right. I use Flintshire Autogas, and Terry there is very knowledgeable about the BRC system.
BRC have a reputation for producing good systems and there are many fitters that specialise in these systems. www.drivelpg.co.uk will show you who is registered to work on them, and you should also know about www.filllpg.co.uk for LPG prices. Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #393494 28th Jun 2016 6:54pm
Yep, totally agree, you will do more harm than good with a flashlube set up, it doesn't need one...
And the guy who did the setup doesn't know what he's doing, it's running lean so get it fixed ASAP or you could (in extreme circumstances) start to melt holes in pistons... Thumbs Up Thumbs Up Pete
Post #393497 28th Jun 2016 7:38pm
Skip720
Thankyou
Any recommendations as to who to use. I live in Wakefield West Yorkshire. And thank you both for your advice.
Post #393507 28th Jun 2016 8:22pm
I know a guy in Hull... Pete
Post #393514 28th Jun 2016 8:40pm
Skip720
Hull is only 40 minutes away. I will give him a go! Do you have any details
Cheers
Post #393557 29th Jun 2016 5:33am
http://www.autogasyorkshire.co.uk/contact/
He's on holiday till Monday... Pete
Post #393662 29th Jun 2016 5:00pm
Skip720
Thanks again
Cheers for that Pete "Haylands"
Post #393675 29th Jun 2016 6:17pm
trickymickey
United Kingdom 2002 Range Rover HSE 4.4 V8 Adriatic Blue
Did you get it sorted ?
Ran a 4.4 with BRC and never had a problem, mine was fitted on outskirts of Sheffield by ORS autogas can be contacted on 01142 487385 , the owner Paul runs a fatty on gas too. Very good service
Post #399875 9th Aug 2016 10:50pm
