Home > In Car Electronics (L405) > Autobiography question, temp dial |
teeleh Member Since: 11 May 2009 Location: Near Amsterdam Posts: 130 |
It's a MY2016 (probably onwards) feature which I guess is very handy and should have been there in the first place. RR's that are part of my car timeline since I bought my first RR Classic in 1999:
27th Jun 2016 8:56pm |
Autobiography Member Since: 10 May 2011 Location: UK Posts: 923 |
Yes 16MY production onwards (Sept 2015-) |
27th Jun 2016 9:17pm |
bear100 Member Since: 22 May 2011 Location: south wales Posts: 204 |
Thanks chaps, it's a nice feature 2010 defender utility
27th Jun 2016 9:21pm |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 |
Yes, as long as it can also be dis-engaged aswell. Assume it can be linked / isolated by the SYNC option in the heater menus (the one I use to link all 4 of my temp controllers together when no one else is in the car) ? Steve
29th Jun 2016 12:37am |
dfulgo Member Since: 16 May 2015 Location: Milan Posts: 70 |
Correct! 2016 RR ATB (Kaikoura Stone w/Brogue/Ivory-Brogue) |
29th Jun 2016 6:04am |
Sync option? 2010 defender utility
29th Jun 2016 7:18am |
Yes, via the infotainment screen. 2016 RR ATB (Kaikoura Stone w/Brogue/Ivory-Brogue) |
29th Jun 2016 12:43pm |
What does that do? |
29th Jun 2016 12:44pm |
If you click the button named "Sync" it makes all knobs set to the same temperature as per the driver's knob setting. 2016 RR ATB (Kaikoura Stone w/Brogue/Ivory-Brogue) |
29th Jun 2016 12:49pm |
Ahh, got you, basically disables the duel climate
29th Jun 2016 12:52pm |
Dual and Multi 2016 RR ATB (Kaikoura Stone w/Brogue/Ivory-Brogue) |
29th Jun 2016 12:54pm |
29th Jun 2016 12:55pm |
Yep, it's useful if people have been in the car and changed each area to different temps , so if in on your own, tap the sync button and as you turn your temp up, you can see the others also going up with it - find it quite handy Steve
29th Jun 2016 11:47pm |
