Home > In Car Electronics (L322) > Mk4 Sat Nav resets when tmc is used
Foulolron
United Kingdom 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
Unusual problem I updated to MK4 nav system around 6 months ago and at the same time updated disk with postcodes / speed cameras etc. For the first time I noticed yesterday when the tmc became active (warning of queuing) the system switched off and immediately rebooted to splash screen, asked if I wanted to continue guiding - accepted and nav came back on but tmc was switched off - audio worked all the time whilst it re-booted (tried a couple of times turning tmc on and within a couple of minutes it would re-boot but only when trying to advise of an issue ahead)
So other than not switching tmc on does anyone have any ideas why it's doing it and if there's a cure - all dry in the boot / amps etc
Post #393010 25th Jun 2016 5:44pm
Weegie
Just a guess but is the TMC using the same protocols as the speed cameras etc and the latter is overriding it? John
GAP iiD BT-Sold
Post #393016 25th Jun 2016 6:40pm
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
The rebooting is caused by a fault in the BMW firmware, when tmc becomes overloaded with lots of messages at the same time it causes the unit to reboot. There has been rumours in the past about an even later release of the firmware then v32 (last known version) that fixes this issue but I have spent 6 years of ownership looking for it on forums. There is only one way to tell the difference and that is on the normal v32 the sat nav vehicle map marker is like a 3/4 circle where as the illusive later v32 has a full circle vehicle map marker. If anyone has this version I would love to here from you!
Matt Current
2012 Range Rover 5.0L SC Ultimate Edition
2012 Range Rover 4.4L TDV8 Autobiography
2010 Range Rover 3.6L TDV8 Autobiography
2003 Range Rover 4.4L V8 Bespoke Vehicle
Inventor of the retro fit paddle shift and many other modifications.
Creator of the custom 2010+ RR MK4 splash screen.
Creator of the Range Rover CarPC and lots more!
Founder of Range Rover Owner
rangeroverowner.com | Facebook.com/RangeRoverOwner | Latest Videos ➞ YouTube.com/RangeRoverOwner
Post #393024 25th Jun 2016 7:38pm
