![]() | Home > General > HSE spec and values |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35610 ![]() ![]() |
never heard of a 2007 hse..... ... - .- -.
themule Member Since: 03 May 2016 Location: Yorkshire Posts: 126 ![]() ![]() ![]() |
Exactly |
DannyH Member Since: 30 Apr 2015 Location: Hull Posts: 221 ![]() ![]() ![]() |
I think that's about the same differences between all the earlier HSE - Vogues isn't it? Don't think there's much else, plus if you think about it it's only an £8k difference so that probably equates to that small list of changes. I've also heard it's a slightly different leather too. Dan 2002 Zambezi Silver Men And Motors RR Quote - It's like having wheels fitted to your living room! |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8747 ![]() ![]() ![]() |
I would doubt that many were ordered, possibly some for government services. I would doubt there would be much difference in comparably maintained/mileage versions in the second hand market, if you could find one. There is nothing that can't be fixed with a hammer😜😜
Go for Vogue/Vogue SE or AB. |
Like Gaz says, the HSE is best avoided if you can. I had an 07 HSE and it was as you say, no Nav, no heating in the back seats, no heated wheel, bottom line stereo, all a bit poverty spec. Fine if it was a Fiat Panda but a RR is expected to have rather more luxury. |
Waynetab Member Since: 19 Jul 2015 Location: Rochdale, Lancashire Posts: 132 ![]() ![]() ![]() |
I have a 2004 HSE with heated rear seats and heated steering wheel. |
idrawcad Member Since: 13 Jun 2014 Location: Sunny Bournemouth Posts: 144 ![]() ![]() ![]() |
I have a 03 HSE, the only down spec'd items I can work out are:
Seems maybe that perception of an HSE is a bit different to the actual differences wrt a Vogue, particularly if a number of options were checked.
Yes, perhaps I should have mentioned that pre 06MY cars were closer in terms of spec, especially since so many people ordered the extras.
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
There's much less difference in cost between specs when buying used, so you may as well find one with all the extras you'd like. |
There was a Hse and se spec available to police and gov services to be ordered. Also in the roi I think you could still get hse for a while as a spec level.
But in the rest of the world, the HSE can be a much higher spec. That's the case for NAS, but I don't know about the rest. |
