![]() | Home > Wheels & Tyres > General Grabber GT's |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
J90,
chawks Member Since: 28 Oct 2013 Location: Dorset Posts: 309 ![]() ![]() ![]() |
Do General grabbers do a 20" tyre do you know? I need tyres with a more chunky tread than road tyres for when I drive into the horses field for harrowing and rolling |
3528cc Member Since: 29 Oct 2014 Location: North East Posts: 301 ![]() ![]() ![]() |
Look up General Grabber AT3's I have just fitted a set 275/45/20's also available in (now) 255/55/20
Marvellous thank you |
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 502 ![]() ![]() ![]() |
i am running Grabber ATs on 20s, over 30k out of them now and still looking strong, very good in fields/gravel tracks. Cheers
Sounds like I need to get some ordered then! |
J90 Member Since: 02 Jul 2013 Location: Somewhere south of Bergerac Posts: 651 ![]() ![]() ![]() |
Nino - they are a lot more road comfortable than the Vreds I had on previously. Tyre wear appears average but there is one disappointment with these tyres, they slip a lot in muddy tracks. I was expecting them to be more sure footed. It's not been a problem so far. They've coped quite well with damp fields but not muddy ruts. Travelling around in circles again. |
Thanks J90, I don't do much mud- more rocks and grass. How do they feel at highway speed, 160-180 km/h.
Nino, very comfortable up to 85 mph. Never been beyond that. I drive with stately dignified indifference |
found a good deal (400 euros) so here they are |
Tyres on mine are 255 50 R20. Would putting a 55 on instead of 50 cause any issues- garage said best to check with Range Rover first as a precaution? |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
It will throw your speedo out slightly, there is a chance, albeit slim, that the speedo will read slower than actual speed.. best to check it against an aftermarket satnav, before you try to go 9% above the speed limit |
275/45/20 and 255/50/20 have the same theoretical rolling diameter, 255/55/20 is +3% Regards
