Home > Maintenance & Mods (L322) > FFRR Service
Page 2 of 3 <123>
mr_spock
RAVE says the sensor screws in to the underside of the filter housing.
Post #389413 30th May 2016 6:11pm
What Mikey said, don't drive it, only buy genuine filters and get it changed ASAP...
Stay well away from Britpart stuff for servicing and repairs, why do you think it's know as 5hitpart..... Pete
Post #389414 30th May 2016 6:14pm
mr_spock
Pete, out of interest, how could the filter cause a pressure drop? Wouldn't the bypass valve still let the oil flow? Or does that bypass the pressure sensor too?
Ian
Post #389417 30th May 2016 6:37pm
Cut one open and have a look, they are nothing like an original one, heard of others having the light on after using one so I presume it prevents oil flow somehow, never looked too deeply into it as I'd never use one anyway.... Can't see the point of saving £10 on an oil filter when a new engine is several thousand.... Pete
Post #389419 30th May 2016 6:56pm
Realist
Wales
Bow down Fixed Rolling with laughter
The problem was when the oil filter was inserted the nipple on the filter was not inserted into its hole, it was crushed flat.
So we now know why the oil light was flashing and why the oil pressure was poor.
For the time being used the old filter new one crushed get a new oem tomorrow.
No flashing light.
No error message.
Misses happy. Range Rover quotes.....
The Luxury That�s More Than a Luxury.
Conquer the world, and look good doing it.
Built for the unexpected.
Over prepared, but never underdressed.
2007 Vogue SE TDV8 Epsom Green (old car).
2010 Discovery 3.0L GS Mk4 Black.
Post #389422 30th May 2016 7:10pm
Thumbs Up Thumbs Up Pete
Post #389425 30th May 2016 7:41pm
Mikey
I would recommend a new garage for your next service. The nipple gets crushed from incorrect fitment. Seen it many times, with expensive outcomes every time...
Post #389426 30th May 2016 7:42pm
mr_spock
Glad to hear it's fixed!
Post #389438 30th May 2016 8:41pm
ajac8
Be good to see a photo of the crushed nipple thingy - is this a easy mistake to make when changing the filter and can it also happen on an OEM part? 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #389444 30th May 2016 9:51pm
Realist
Wales
It could happen on any make of filter and shows you how important a clean unblocked filter is. Range Rover quotes.....
Post #389450 30th May 2016 10:07pm
Mikey
TDV6 engine, but similar design of filter
Post #389452 30th May 2016 10:21pm
Mikey
There is a hole inside the filter housing to locate the nipple into, then the filter cap screws onto the housing
If you push the filter into the cap, and screw it in, this is completely wrong and causes the above to happen, and can happen with any brand of filter. But Britpart filters are best avoided, IMHO Thumbs Up
Post #389453 30th May 2016 10:22pm
Realist
Wales
I'll get a better filter tomorrow cos I reused the old filter for now.
No Sh*tparts from here on in and yes the above pic is what happened. Range Rover quotes.....
Post #389456 30th May 2016 10:27pm
Mikey
This was the aftermath of said TDV6 with incorrectly fitted oil filter...
Post #389458 30th May 2016 10:39pm
Realist
Wales
Bloody hell. Range Rover quotes.....
Post #389540 31st May 2016 5:32pm
Page 2 of 3 <123>
