Home > General > Audio problems MY 2010
robbi
Guernsey
Guys,
I have a MY 2010 TDV8 Vogue and for the third time I have started the car and had no audio no matter what the source.
The first time it happened I tried everything to fix it and then found that if I pressed the Nav speaker icon (ie. to repeat last instruction) the audio would work but only for as long as the Nav command lasted.
It's been in garage but I assume they didn't find the fault. The fault only seems to last until the next time the car is started from being left, normally overnight. The first time it happened switching car off and then shortly back on didn't fix the problem.
Anyone else had this issue???
Rob
Post #38016 22nd Nov 2010 9:08pm
Java Jungle
Monaco 2011 Range Rover Autobiography 4.4 V8 Nara Bronze
Rob, happend to me twice, started the car and no audio. It might be a different problem though since it was fine after switching the engine off, closed the doors and starting the engine again...
JJ
Post #38304 23rd Nov 2010 12:06pm
robbi
Guernsey
Thanks. I'll give that a try!
Post #39238 25th Nov 2010 9:56am
