Home > Technical (L322) > td6 l322 rear wheel speed sensor open cct |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35263 |
check the abs wire for breaks or chaffing.. ... - .- -.
22nd Jan 2016 2:33pm |
bleeperman Member Since: 01 Nov 2012 Location: lancs and Anglesey Posts: 109 |
Any idea where the plug skt is from the sensor it is not obvious? Been underneath today but access is not good when suspension inactive. If it ever stops raining I will have the wheel off! |
24th Jan 2016 5:17pm |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1340 |
you need the wheel off , its tucked behind the plastic liner at about the 11 o clock position |
25th Jan 2016 8:41am |
frenshy Member Since: 11 May 2016 Location: birmingham Posts: 3 |
Wondered if anyone has had the same problem as me with this..
11th May 2016 5:46pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8186 |
It is NOT a hard fault, i.e. it doesn't need turning off it just goes when the fault is fixed.
11th May 2016 6:05pm |
Make sure you have fiited the correct sensor for yor car , I bought one from ebay as my model was listed as correct , unfortunately this wasn't so , ended up sending the car to well known independent in ncl for diagnostics and they billed me for a repair to loom ( bullshit ) and told me the abs module needed replacement (more bull) they didn't diagnose the wrong sensor was fitted , it was only when I double checked the resistance against against the other sensors that the error was duscovered |
11th May 2016 6:35pm |
Yes abs sensors are a pain my rear was correctly diagnosed and fault cleared as soon as motion applied. Good tip the old sensor was jammed solid only tool effective was a flat wood drill but grind the point off first and be careful not to damage castle teeth on axle. I had a front sensor diagnosed wrongly once so just change the other to rule sensors out. |
11th May 2016 9:49pm |
Thanks for the info guys. Took it to a local indy and they saying that its showing an "open circuit" to the sensor and suggesting that its either wiring or more likely, the abs control unit !!
17th May 2016 12:20pm |
