![]() | Home > Technical (L322) > Windscreen washers |
Brydo Member Since: 11 May 2016 Location: Scotlannd Posts: 17 ![]() ![]() ![]() |
My 04 td6 vogue washermotor working all water pipes pressurising but no water coming out the unblocked jets. What is going on??? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8405 ![]() ![]() ![]() |
Pull the pipes off the jets and see if anything comes out, if it does, clean the jets better, if it doesn't work pull the pipe off the pump and blow it through with an air line, from the jet end.... it'll be blocked somewhere.... Pete
Thanks Pete I will try your suggestions |
