I see lots of posts mentioning cooling system airlocks but not many on how to cure them!
Changed the rad in my 4.4 AJ V8 this afternoon (using the slam panel method, will update on that another day, not to mention recommendations on where NOT to buy your new rad, and no it's not Britpart!) but now the heater blows stone cold when the temp gauge is reading normal, and eventually the system boiled over through the bleed screw on the expansion tank. Are there any other bleed screws I can get to? Or any other method to cure this? I still have some work to do (the drain plug on the new rad leaks luckily I only put water in so far, to check for leaks), so I need to cure that which will drop a lot of the coolant again. I'll replace with the good stuff once it's water tight, but then I need get rid of the airlock. All help muchly appreciated!
Edited for terrible spelling & grammar, I originally wrote this in a rush with still-oily hands!
