Home > Technical (L322) > TDV8 Vacuum Line locations...
MattChaloner
England 2016 Range Rover Vogue TDV6 Loire Blue
Hi all,
Just been replacing my EGR valves - got the old ones off, new ones on and just putting it back together. I'm having some trouble though - I only remember removing 1 vacuum line which came off the inlet manifold near the fuel filter, but I'm sure it should have a curved rubber tube on it to push onto the connection? this seems to have come off/been misplaced, so wondering if anyone knows if a replacement can be bought without having to pay the full £99 for the whole vacuum line set from land rover?
I've also got a spare vacuum line which seems to want to be located at the back left of the engine (drivers side in UK) its got a right angle rubber tube on it but can't find anywhere for it to push onto, and don't seem to be able to find a diagram showing the location of each of the pipes.
Also, a bit of a strange one, when I was unplugging the engine harness the big black plug with the red sliding lock at the very back of the engine didn't seem to be plugged into anything much; its got a connector plugged into it but seems to be full of little green blanking plugs for each pin? It's a 2009MY, was this not used on the later model TDV8 or have I inadvertently ripped all the wires out of the other end of the plug?
Post #386551 11th May 2016 10:21pm
wealy
United Kingdom 2014 Range Rover Vogue SDV8 Luxor
Scrap yard?
Post #386557 11th May 2016 10:49pm
