Home > Maintenance & Mods (L322) > [SOLVED] No Screen (non touch), No radio, No indicators |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
It's worth a look Pete, not been in there (ABS ECU) before
Hmmm since the warm weather the aircon has been running.....? Only other electrical thing to report is a couple of times a few weeks ago the alarm went off with car sat locked in bright sunshine. Never know what this might have been, a spider? Or not related in any way? Perhaps it is just my turn at the gremlins . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
19th May 2016 10:24pm |
@ fisha
20th May 2016 9:35pm |
Well, having behaved itself for four weeks, it did it again on the way to work on Wednesday. On the way home everything worked on start up then it died on the way home. On Thursday did much the same thing. Friday morning worked fine on start up but died on the way, but behaved itself all the way home.
24th Jun 2016 5:13pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8266 |
That's about all that's left Tim, will be easy to see if water has got in, there is a lot of unprotected bare steel behind there that get's very rusty with a small water leak...
24th Jun 2016 8:17pm |
Still doing it!
6th Aug 2016 4:46pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 |
Have you considered any corroded earth points behind the dash? |
6th Aug 2016 5:08pm |
Behind the dash is my next port of call, once I have exhausted everything else. Only a problem after it has rained, so water going somewhere, doing something, so seeking the source (a bit like Livingstone & Stanley ) .
6th Aug 2016 5:28pm |
Update: promising
25th Aug 2016 5:03pm |
Bah! Following the torrential rain last night, everything died again 10 minutes into my journey to work!
16th Sep 2016 5:22pm |
Tim, Have you got the original or an old windscreen, mine was the original and when they changed it a few months ago there was a section at the top of both "A" pillars, about a foot long, where the bonding had failed and the screen had lifted, also had numerous other places where it had failed, you could see the dead areas easily after the screen was cut out as the cut areas looked new and fresh... if you have an old screen, maybe worth the small excess to get a new one...
16th Sep 2016 6:13pm |
Screen about six years old, defo not the original.
16th Sep 2016 7:59pm |
16th Sep 2016 8:55pm |
Well and truly flummoxed by this one!
18th Sep 2016 2:58pm |
Thought this one was worth an update (9 months on)
20th Jul 2017 4:27pm |
