![]() | Home > Technical (L322) > Manually changing transfer box range |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6416 ![]() ![]() |
You have a few of options:
mr_spock Member Since: 07 Apr 2016 Location: Welwyn, Hertfordshire Posts: 311 ![]() ![]() ![]() |
Hmm, I'd considered powering the motor. I've already made up a lead and tested on the bench, so could reuse that. Do you think I could just use the motor, unbolted, to rotate the splines?
I would bolt the motor back on, ensures it winds to the right place, if this doesn't work, then will help with fault finding.
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
Have you tried switching the box into neutral using the fuse removal process to see if it finds itself, it knows where it is due to the potentiometer I believe and it's this that fails requiring the motor to be replaced.
When I reattached the motor it went into high and low ok. Then it got confused and threw the trans fail safe. Now it's not quite in neutral - no drive but a little graunchy - so I think the worm gear is still in the middle of its travel.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8413 ![]() ![]() ![]() |
Worth a try Ian, can't understand why it was OK and then not.... |
This is what is inside, not sure if it helps much, RRPhil had a sectioned view on youtube of the actuator moving but it's not there anymore.
Thanks all. I found the youtube vid by RRPhil with the cutaway box, very helpful. I guess it's possible that when I glued the pot together again some glue may have got on the tracks and is somehow blocking movement. My plan is (unless someone has a better idea!):
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35528 ![]() ![]() |
i'd try #8 first... |
I would try and read / clear any codes first and then try the transfer box neutral procedure.
I opened the transfer box motor potentiometer to tweak the contacts. I'll be checking the resistance again tomorrow just in case I mucked it up, but I don't think I did. |
OK, it seems to be working now. Although I'll be more confident after some road time, especially when cold. So far:
I stopped getting notifications, how are you getting on ? |
I took it out for a short drive yesterday and had no errors! I think (hope) that's done it. |
