Home > Maintenance & Mods (L322) > How to remove brake shields 2010MY |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6370 |
So, after the local garage messed about and determined my brake shields are rotten they now rattle like a very rattly thing and I need to remove them.
28th Apr 2016 3:59pm |
I think it changed for the 2010 onwards cars from what people have said in the past, RAVE is not that up to date though sadly. Discovery 4 HSE
28th Apr 2016 4:42pm |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2655 |
I used tin snips. Can you not put big washers on ? Or are they too far gone? |
28th Apr 2016 5:59pm |
How close to the fixing bolts is it possible to tin snip them off??
28th Apr 2016 8:50pm |
I was pretty brutal with them tbh, I got really pjssed off with the embarrassment cause the noise was ridiculous . I think I did quite a few cuts & a fair bit of jiggling about. I would certainly go for the big washer route 1st, no farting about, just do them one bolt at a time, to be honest, all you need is something to be bigger than the corroded hole, you could even notch a washer to slip on without taking the bolt out |
28th Apr 2016 9:33pm |
tanertimur Member Since: 17 Sep 2011 Location: London Posts: 90 |
I had the same issue with my shield and used "quik steel " which is a putty type compound you play with it like playdoug mixing it. As you feel it heat up you then apply it and it turns very hard hence the name. I applied it on the shield by the hold wedging it and it stopped the shield from rattling.
29th Apr 2016 6:33pm |
