Home > Maintenance & Mods (L322) > Facelift headlights wirings
AzizRR
Bahrain
Hello
I am in middle of doing a front conversion for 2009 vogue..
For experts in doing conversion what do you suggest to make headlights work perfectly like oem.
Is there a wiring diagram or trick to prevent fickering and make afs works like it should.
Need help asap as my car sits in the garage waiting for a good solution
Regards
Post #383703 25th Apr 2016 2:58pm
JPHC
Aziz, I'm no expert on the subject but I do remember reading that the AFS wont work as the modules aren't compatible. The headlights still function fine without it though.
Post #383704 25th Apr 2016 3:08pm
AzizRR
Bahrain
Not interested that much in AFS as long as everything else works fine
Post #383710 25th Apr 2016 3:38pm
Spooky
United Kingdom 2014 Range Rover Autobiography 5.0 SC V8 Corris Grey
What sort of 'fickering' is the problem???
p.s. just around the corner in the Elite Spa at the mo! Regards,
Mick
'Bertha' - 2014 SDV8 Autobigraphy
'Vincent' - 2010 TdV8 Vogue SE
- 'Molly' - 2005 HSE Auto
'Dixie' - 2000 D2 Td5 ES
Post #383733 25th Apr 2016 5:44pm
AzizRR
Bahrain
Can't believe you noticed that typo lol
Post #383734 25th Apr 2016 5:49pm
Spooky
Maybe, but what flickering is the issue??? Regards,
Mick
Post #383736 25th Apr 2016 5:52pm
"Adaptive headlights" were for <2010 cars, it was then replaced by a similar thing called "AFS" post 2010 (facelift). The 2 systems are not interchangeable and can't communicate with each other, so the bottom line is, if you had "adaptive headlights" and upgrade to "AFS", they won't work in the way they are supposed to, so they'll only point forward.
I disabled the Adaptive feature using my IIdtool, as you'll get errors every time you start the car. Got - 2017 SDV8 Autobiography in Loire Blue
Post #383738 25th Apr 2016 5:57pm
Stryke
AFS wont work unfortunately. A few experts have tried, all to no avail.
For flickering and brightness I fitted the front interface modules. Headlights work correctly and no random indicator flashes.
Post #383739 25th Apr 2016 6:04pm
AzizRR
Bahrain
What about the wiring? Could you please help me with that?
Post #383741 25th Apr 2016 6:04pm
are there no wiring details in the conversions in the wiki? ... - .- -.
Post #383747 25th Apr 2016 6:14pm
AzizRR
Bahrain
There is but mostly for pre 05 models
Post #383750 25th Apr 2016 6:28pm
is this any good?
Post #383767 25th Apr 2016 7:11pm
AzizRR
Bahrain
It is just what I needed, but too late i ordered the box module lol
Post #383770 25th Apr 2016 7:15pm
