Home > Maintenance & Mods (L322) > very slow seatbelt retraction on both front seats |
Pvw10 Member Since: 04 Nov 2015 Location: Ledbury Posts: 315 |
I had this on my car plus my X5 and learned a trick on a X5 forum.
24th Apr 2016 1:06pm |
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 417 |
Try cleaning the belt itself, I need to do mine as I get the same and have to feed it in the last bit.
24th Apr 2016 1:09pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35331 |
coincidentally i just did mine with a wet wipe that i used to clean the leather...seems to retract better now.. ... - .- -.
24th Apr 2016 1:12pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8239 |
It'll make a small difference but the trouble seems to be within the seatbelt itself, that bit at the top does stop it somewhat but it is the return spring in the seatbelt itself... you can't change any part of the seatbelt, for one thing they don't sell bit's and you can't get it apart and back together anyway..
24th Apr 2016 1:31pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
They are available for one model year at around £60... Maybe an 09>??? |
24th Apr 2016 1:41pm |
Interesting Craig, I did find different numbers for them, some to do with colour and some with years... maybe worth a chat with Dan... Pete
24th Apr 2016 1:48pm |
Indeed... |
24th Apr 2016 1:54pm |
Try LR010936 Pete |
24th Apr 2016 1:58pm |
Ohwhatalad Member Since: 27 Jun 2015 Location: Cambridgeshire, South East Posts: 191 |
thanks guys very helpful, i think it does just need new ones but ill try with some sillicone spray first to see if it makes it any better |
24th Apr 2016 2:06pm |
Cheers Craig, just got a brand new one off eBay for £50 delivered so we shall see if it fit's OK....
24th Apr 2016 6:14pm |
let us know how you get on please pete, ill order 2x if they fit and work well.
24th Apr 2016 6:41pm |
Interesting. I had the same on SWMBO's Jag XF. Cream belts which were looking grubby so I cleaned them with a wet vac. I wasn't trying to cure the slow retract but it did fix that too. If you'd seen the colour of the water in the vac after I finished you would have been quite shocked. It was beyond filthy. |
24th Apr 2016 7:39pm |
It fits...
27th Apr 2016 7:16pm |
rathbranV8 Member Since: 23 Jan 2011 Location: meath Posts: 283 |
Furniture polish like mr.Sheen if you have it around.Pull belt out fully and spray both sides.Did it to mine for test recently.Saves buying silicone spray |
29th Apr 2016 4:33pm |
