Home > Off Topic - Other Cars > Spark Plugs - Which are best
Rosco
Well with the purchase of a stupid hill bike I now find that I am actually a mechanic Rolling with laughter
Bloody spark plug is black, cleaned it and now black again, so will have to replace it and probably more... anyway, current one is a Denso so I am looking for recommendations for a good one if this one is not good! Maybe replace with same, I havent a clue
Many thanks all
Rosco Bow down
Post #383255 22nd Apr 2016 6:17pm
miggit
The best thing to do is clean the air filter, as you is running too rich matey and your burning unnecessary fuel Shocked Shocked I'm not sure what the OEM plug is for a Kholer engine, but I have found that NGK plugs are good on single cylinder engines...... by the way what was the starting problem? dirty plug? you might need to adjust the mixture on the carb.... which is a bit of a black art.... still reckon that a trip to the mower shop might pay dividends in the long run Thumbs Up
if you could give a bit more info on the engine I might be able to steer you in the right direction..... Kohler make hundreds of different engines.... it's not just a case of 6hp... there's probably 20 different types to choose from Shocked Yesterday I couldn't spell Engineer... Today I are one!
Post #383274 22nd Apr 2016 10:42pm
Rosco
Cheers Miggit, I will try the NGK, its a Kohler Command Pro 6. With plug cleaned it starts and runs perfectly but then plug soots up so I assume the carb is running rich as you suggest, will try a new plug first then tackle the carb Thumbs Up
Post #383296 23rd Apr 2016 6:51am
miggit
Take the air filter off and try that..... don't blatt it down a dusty track..... but running it stationary wont do it any harm..... and could prove if that's the fault before drastic surgery is advised Thumbs Up We aren't talking Range Rover technology here... it's a 2 wheeled lawn mower without any blades Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #383315 23rd Apr 2016 8:24am
miggit
Shocked Shocked They've been making that engine for years... and changed the the thing so much.... it's gone from this
To this
Which is a knock off Honda design..... and then there's the little matter of fuel tank, reckon that will have been stripped off, so it probably wont look anything like the above...... This is your chance to be David Bailey Mr. Green Yesterday I couldn't spell Engineer... Today I are one!
Post #383319 23rd Apr 2016 8:43am
Rosco
The second picture is exactly the one, will try the air filter option today cheers Thumbs Up
Post #383321 23rd Apr 2016 8:47am
miggit
Have you ever thought about an engine upgrade..... something like this could be made to fit....
http://www.ebay.co.uk/itm/LF178FDQ-6Hp-L70...Swqu9VOlk0
you could then run it on Red diesel..... or for that little extra zoom Deep Fried Mars Bar Fat Shocked But you'd better keep an eye of for the Polis Wink Laughing Laughing Yesterday I couldn't spell Engineer... Today I are one!
Post #383324 23rd Apr 2016 8:59am
miggit
the air filter is under the plastic cover with the nut on the top.... you'll probably find another nut under that holding the filter on..... there might also be a removable foam band over the filter, this can be taken off, have the crap knocked out of it and replaced..... Twisted Evil that'll teach it Twisted Evil Yesterday I couldn't spell Engineer... Today I are one!
Post #383325 23rd Apr 2016 9:05am
miggit
Post #383328 23rd Apr 2016 9:12am
Rosco
Thanks Miggit, have already dismantled it and cleaned filter, just having problems sourcing spark plug, cant get one till Monday, gap on old one is massive Thumbs Up
Post #383341 23rd Apr 2016 10:28am
miggit
Shocked err, ever thought of giving it a little tap on the nose?.... if you hold the plug and gently tap it (2-3 inch movement, not dropped from a great height) on the nose with it's own weight, you see the gap close up.... it wants to be about 25 thou or 1 mm max and 15 thou or 0.6mm minimum, if you over do it then it's possible to open it up again but be very gentle as they can snap the arm. Thumbs Up
Post #383357 23rd Apr 2016 12:58pm
miggit
Kohler recommend a Champion RN14YC plug.... that's a middle of the road plug, and one of the NGK equivalents is the BPR5ES...... that is the standard Honda plug..... and it also happens to be the standard 3.5 V8 Range Rover plug too. A BP5ES will also do the job, surely they have invented Halfrauds in your neck of the glens.... failing that what about a local Golf Club, most of the kit that they use will be Honda powered, they might have a spare plug Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #383358 23rd Apr 2016 1:10pm
CS
Honda 4 stroke engines also used in lawnmowers, log splitters etc so suppliers of these might have plugs too. But limited point in changing plugs if reason for fouling not eliminated. Only Range Rovers since 1988
Post #383373 23rd Apr 2016 4:08pm
Rosco
Manual says NGK BPR4ES, so have ordered one for Monday as no one stocks them, also was told the Denso equivelent is a different one from the plug it had in, I know it wont solve issue but another item eliminated Thumbs Up
Post #383377 23rd Apr 2016 4:22pm
miggit
The temperature range difference between a BPR4ES and a BRP5ES is minimal and is very unlikely to effect the running of the engine..... it's only when you get it horribly wrong that things can take a turn for the worst.... to low heat range and it could melt , or act like the rods that you heated with a blowlamp on the very early petrol engines, and you'll never turn it off Shocked Too high and it could get wet or foul up..... wonder where I've seen that before Rolling Eyes
CS buddy, why do you think I suggested going to a Golf Club, I believe that they cut grass at such an establishment Wink Laughing Laughing Yesterday I couldn't spell Engineer... Today I are one!
Post #383379 23rd Apr 2016 4:38pm
