Home > Technical (L322) > Rear camber
chex
Kenya
Rear camber
I noticed a couple days ago that the rear camber seems excessive, to the naked eye. It's similar on both sides (not been measured by a tire centre yet).
Does this look off to you guys?
 2004 L322 V8
Post #382707 18th Apr 2016 11:39am
comports
On the face of that picture it does look out (by a long way) but pictures can be deceiving.
Easy way to tell is the tyre wear... Based on the image I would suggest the inner edge would be quite warn and the outer hardly at all.
Best run it down to somewhere for an alignment check Ash
2016 SDV8 AB
Post #382715 18th Apr 2016 12:49pm
rathbranV8
Ireland 2002 Range Rover SE 4.4 V8 Oslo Blue
That looks wrong.did you hit a rut or something recently to knock the alignment out.Either that or your upper hub bushes/camber bolts are on their way out...garage time again
Post #382834 19th Apr 2016 9:28am
loks like you are parked sideways on a slope..it could be low pressure in the tyre which with its high sidewall gives you that appearance.. ... - .- -.
Post #382840 19th Apr 2016 9:48am
holidaychicken
I had mine 4 wheel tracked at Kwik fit which was pretty extensive and the tracking and camber can all be adjusted provided your bolts are not seized solid inside the bushes on the inner track control arm or outer hub. A common fault is the upper and lower hub bushes that I changed on mine along with the track control arm and all relevant adjusters and bolts.
As already mentioned , tyre wear would tell you but Kwik fit would check and if they can't adjust they wouldn't charge you
Ok so just realised the OP is in East Aftica, probably not going to a Kwik fit out there, check your tyres
Post #382910 19th Apr 2016 9:11pm
RP123
Scotland 2006 Range Rover HSE Td6 Bonatti Grey
Just a thought ..
In the photo - is the car in access height (i cant tell from the photo)- The suspension's pivot point makes the wheel move in an arc - the higher the wheel (or lower the body)the more the wheel's camber will change to negative. Having said that it does look odd in the photo.
Regards
Simon
Post #382944 20th Apr 2016 8:55am
chex
Kenya
No, it's at normal height with the engine running.
It's on level ground, the camera is crooked. It's not often on level ground or tarmac which is why I never noticed before...
Changing all bushes in a couple of weeks will hopefully sort it. It's squeaking at the back as well so bushes are most prob worn... 2004 L322 V8
Post #383114 21st Apr 2016 6:33pm
sako243
Comparing it to the front wheel I'd say it's got quite a lot of camber on it. Ed
Post #383133 21st Apr 2016 8:04pm
chex
Kenya
I wonder if it's exaggerated by the 32" tires.
I parked next to a ffrr with 255/55r19 tires yesterday and they looked like toy tires...
looking again at the image it looks like the wheels themselves may be quite straight but the bulge at the bottom of the tire makes it look like it's leaning more than it is? 2004 L322 V8
Post #383463 24th Apr 2016 9:11am
Road Stone
G'day Chex,
Did you get this issue checked out?
Cheers, Jerry THIS WRECKAGE
Post #383613 25th Apr 2016 6:01am
chex
Kenya
im going into town in a couple weeks to have it checked and change bushes (i have a full set lying in my store for some time now) 2004 L322 V8
Post #383614 25th Apr 2016 6:10am
