Home > Technical (L322) > Transmission fault and loads of lost communication, TDV8 3.6 |
Edfors Member Since: 26 Oct 2012 Location: Uppsala Posts: 168 |
I get the below error messages and vehicle gets special programs off and transmission fault on the instrument cluster and then only gears up to third. After resetting all goes away, and all seems normal. But then it returns and I have to to another clearing. Any ideas? Are there any common connector which fails? I have been driving on wet roads with lots of puddles.
28th Mar 2016 6:53pm |
Blade74 Member Since: 30 Apr 2015 Location: Sydney Posts: 55 |
When was the battery changed last? and what has its life been like? |
30th Mar 2016 8:51pm |
Paul1234002 Member Since: 06 Oct 2015 Location: Manchester Posts: 32 |
Have you resolved your issue? |
5th Oct 2017 5:26pm |
No, battery was replaced, no difference. was also charged numerous of times.
6th Oct 2017 9:19am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2469 |
A wild shot, but does the right rear seat get used? A wiring harness that runs from the right rear quarter panel passing close to the back of the seat can take a short-cut then get pinched by the seat, causing several unrelated faults when wires short together. Easy enough to check anyway. |
6th Oct 2017 8:44pm |
2nd Apr 2018 5:12am |
