Home > General > TD6 things to look out for?
linzwillo
Wales
considering buying an older model I have read gearbox problems an issue.
any advice on what to check for before purchase
Post #379461 26th Mar 2016 9:43am
Check the buyers guide in the wiki Thumbs Up .
Post #379472 26th Mar 2016 10:25am
rear subframe bushes
coolant level sensor
auto box
thermostat
water pump
secondary fuel pump
egr ,filter and breather
high/low shift motor
front air spring
front ball joints
folding mirror
fuel burning heater
glow plugs
diesel injectors
To name but a few... basically you need to check and recheck everything on the motor, crawl underneath and inspect everything as well... take a friend to look at it with you who can stop you getting all starry eyed and buying the first you see...
Read the WIKI on here for tips on all the common problems....
Put a wanted add on here and get one that's been looked after by someone who's an enthusiast...
TAKE YOUR TIME.... it's a buyers market...
Oh and I know you probably won't but forget the diesel and buy an LPG petrol, faster, smells better, more economical, better gearbox.... (but I would say that...) Pete
Post #379474 26th Mar 2016 10:34am
RR2008HSE
Any car can have any fault. You already know about the gearbox and the wiki, so there's good advice there.
I think Haylands is onto something as well. I've never run LPG (or diesel) as petrol makes the most sense here, but I'd seriously consider it in the UK. And those BMW V8 seem to take to LPG the best, although any can be converted.
Post #379539 26th Mar 2016 7:45pm
