![]() | Home > General (L405) > Automatic time update |
Charlyfarly Member Since: 26 Jun 2015 Location: Warwickshire Posts: 210 ![]() ![]() ![]() |
Am I being thick, or is it the case that my L405 Autobiography does not auto adjust for daylight saving time?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35465 ![]() ![]() |
it only takes a few seconds to do it manually...not sure about the L405 but on the L322 you can see the hands move on the clock.. ... - .- -.
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1390 ![]() ![]() ![]() |
Alas you can't see the hands moving on the 405 .... as there is no clock. Only Range Rovers since 1988 |
I know it's dead easy on an L405, just touch the digital time display but I'm just amazed that it doesn't do it automatically, especially when travelling abroad. Maybe it's a Windows 2.11 system ![]() |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
For auto-daylight savings time, your car needs to know exactly where it is (not all jurisdictions do DST), and when to do it (not everyone does it at the same time). It's fine on a computer or phone that regularly has an Internet connection, but a bit more problematic on a car. Knowing you have to do it manually is a less serious problem than a car that does it on its own and gets it wrong. Resetting the clock in my old Honda was a huge exercise in frustration. At least in the L322 it's fast, simple and easy. I would hope the new ones aren't any harder. |
^ Wot he said |
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 544 ![]() ![]() ![]() |
Why can't the radio data be used? Isn't that how my £10 clock radio does it? Drives:
Doesn't the satnav know precisely where the car is at all times? Even the inControl app on my phone knows where my car is ![]() |
Declan303 Member Since: 08 Dec 2015 Location: Meath Posts: 151 ![]() ![]() ![]() |
I always adjust the clock manually, god knows we can do with the bit of exercise |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3242 ![]() ![]() ![]() |
Last October I set the time using the touch screen. The time stayed fine for a few hours then suddenly went to 12 O'Clock. Stayed like that for a few minutes and then reset itself to the correct (updated) time.
just leave it as is for 6 months and then it'll correct again... ... - .- -.
6 months, Stan? Swindon different from UK? |
I don't think we use RDS data over here. Also, even in the Range Rover and not wilderness roving in the old Disco, I can easily get out of range of all radio and mobile signals. (BC = lots of mountains + few people.) In fact, just got a HAM radio licence for safety when there's no other means of communication. |
I just thought some more about this. Actually, GPS + satellite radio (which has data) should be able to sort that out. Generally, satellite radio is continent wide, so that's not a huge number of providers to work with. It does require a subscription, but new car dealers often throw in a year. |
