Home > Maintenance & Mods (L322) > What size is the bolt that holds the swan neck to tow bar. |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 |
Went to change the swan neck to multi height tow hitch, only to find my largest socket 22mm is too small. I did not want to mangle it with a large adjustable so gave up for today.
20th Mar 2016 12:47pm |
gbmud Member Since: 19 Feb 2016 Location: Sussex Posts: 19 |
24mm, or 15/16" on mine.
20th Mar 2016 12:54pm |
Thanks for that, may just have an old ring spanner that will fit from 30 years ago. |
20th Mar 2016 2:06pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1385 |
I also found this impossible to remove with normal hand tools, including 2' bar on main bolt. You will probably need a spanner on the other side too, to stop the bolt turning, if you can get it moving. LR seem to assemble this dry which makes it harder too. Once mine had been freed off I coppergreased the thread. You might find the stem of the tow bar holder stuck in with rust too, in my case it had to be hammered out. I coated it with Vaseline when I put it back and again that made removing it subsequently easier.
20th Mar 2016 7:53pm |
Thanks guys, this easy job turning into a major Easter weekend event.
20th Mar 2016 8:01pm |
Well the nut was tight. Set vehicle height to rock hopping, put socket and long bar on the ground, let vehicle down to normal, get out and nothing broken still plenty of leverage room so let it down to access height, get and get under and yes it has budged. Adjustable on bolt head and a few tight turns and it was free to use the socket ratchet. Bolt needed to be drifted out and the swan neck slid out.
25th Mar 2016 3:44pm |
