Home > Maintenance & Mods (L322) > Car polishers
Markjohns1
Car polishers
Looking at treating myself to a dual action car polisher,all look much of a muchness any one able to advise as prices seem to vary ,will probably only use a few times a year so dont want to be spending mega bucks ,advise. Info much appreciated
Post #377840 16th Mar 2016 8:59pm
n1cktdv8
I am toying with a Makita Orbital but they are pretty expensive (for what I'd use) so I am hunting for a used one ! Is this where I put the car details and a bit about myself ?........
Post #377850 16th Mar 2016 9:18pm
Mr Tee
Here you go , been using this kit for a few years years , amazing results :
http://www.polishedbliss.co.uk/acatalog/pb...erZ0000IP1
Post #377854 16th Mar 2016 9:33pm
Click £99.95
Click £54.99
Click £67.50
Post #377855 16th Mar 2016 9:33pm
Wenners
United Kingdom 2009 Range Rover Vogue SE TDV8 Zermatt Silver
I've got a Das-pro from Clean your Car, would highly recommend.
I've achieved some great results with it and personally wouldn't go for an orbital, stick with a dual action as it's far less less likely you'll do any damage or polish in more issues than you started with!
Post #377884 16th Mar 2016 10:40pm
acrr1
United Kingdom 2002 Range Rover Vogue Td6 Oslo Blue
Another vote for the DAS6 pro - have had one for years, great bit of kit (also purchased from Cleanyourcar). Avoid the basic DAS6, the pro and pro-plus both have more powerful motors and a longer 6 metre cable.
Post #377940 17th Mar 2016 9:24am
mzplcg
+1 for the Makita. That's all I use now. Various DA machines have come and gone (usually gone bang) along the way but the Makita keeps going. It's also way more powerful with its constant torque motor than a lot of the competitors and because it's rotary rather than Dual-Action it won't vibrate your fillings out or make your hands tingle for days.
Expensive? Depends if you value quality and servicability really. Try buying a set of brushes for a cheap chinese import. Thumbs Up
Post #377941 17th Mar 2016 9:29am
archermav
United Kingdom 2016 Range Rover Autobiography SDV8 Corris Grey
I've had a DA polisher sat in the garage for a couple of years now. Never quite worked out which pad does which and in which order. Really must sort it out and give it a whirl (perhaps on the wifes car first though)
Post #377962 17th Mar 2016 10:55am
Seconded for PolishedBliss. Thumbs Up
I bought my DA polisher from there, plus a lot of other stuff as well, and their knowledge and service is exemplary. Si. <This is my name.
Post #377980 17th Mar 2016 12:55pm
pld118
I've got a heavy duty industrial type rotary polisher that gets dusted off now and again. Had it 15 years. It was about £200 odd then and did implode once many years ago but it got fixed and is a mean piece of kit in the right hands (think it's a Sealey but would need to check). Just need to find someone who can work it properly Laughing
Post #378056 17th Mar 2016 7:22pm
