Home > LPG > LPG Service required on 4.4V8 2005 G4 in Kent
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
Big Boy R44ROV wrote:
The old Rover V8 3.5, 3.9, 4.2, 4.6 Suffered massively if you put LPG on them. particularly the 4.6. They suffered the symptoms mentioned earlier. I know. Having had 2 engines that went completely. One just the day before as I was ready to PX !! Big Cry
Sorry to hear you had problems, though I did 90k with the 4.6 on LPG and had no issues with valve or cylinder wear.
The big problem with the 4.6 (and less so the 4.0) was coolant loss leading to overheating (because Land Rover tried to save money by not fitting a low coolant level warning system). Once the engine had overheated, tiny cracks in the thin aluminium walls led to the liners moving, which led to more coolant loss as the head gasket no longer sealed properly against the liner top (one fix for this was the top-hat liner system).
I saw lots of problems with Range Rovers fitted with the 4.6 engine. Mine needed head gaskets at around 140k, though that was no different from cars with no LPG system fitted. Perhaps I was lucky, but I do put part of it down to meticulously fixing any problem that was causing coolant loss. Sold it at nearly 180k with the original engine and was still running as sweet as the day it came out of Solihull. Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #393404 28th Jun 2016 10:29am
