Home > Technical (L322) > Unidentifiable connectors in the engine compartment. |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
I have a few spares on my M62 2004, do you have secondary air injection unit (SAI)
15th Mar 2016 10:36pm |
Pepi Member Since: 04 May 2015 Location: Doncaster Posts: 125 |
Yep top end connectors all seem to be in the right places.
16th Mar 2016 9:01am |
Hi thanks for taking the trouble to come back to me on this.
16th Mar 2016 12:56pm |
The SAI kit is under the air filter box as you say and you have pipes running along the front of the engine i believe, i am sure it's only or emissions for when the car is first started to pump in more air while its on 'choke'.
16th Mar 2016 8:06pm |
Have a look at saints 'how to' over on the other side.
16th Mar 2016 9:55pm |
Well that would explain it!!!!!
17th Mar 2016 12:43pm |
Nope, i think i'm on my third MOT and as you say emissions are perfect, think it's just for when it's first started to tick some box somewhere no doubt |
18th Mar 2016 1:02am |
Think I may have a much bigger problem now.
18th Mar 2016 2:02am |
Don't panic, i have been there a few times, engine noise or transmission ? |
18th Mar 2016 7:26am |
Worked out and sorted the gearbox just after I bought it. A flush and a new position switch sorted that.
19th Mar 2016 9:52pm |
Well it sounds to me like you are fully infected with the range rover disease and unfortunately there is no cure so i am afraid you are in the for the duration.
19th Mar 2016 10:05pm |
Valley pan looked as though it had been weeping but difficult to assess because of oil and dirt build up.
19th Mar 2016 10:36pm |
Malt sounds good, more of a guinness man myself, if i have learned one thing about the car, its good diagnostics.
19th Mar 2016 11:55pm |
Insomnia worrying about the bloody car. Eddie the eagle watch out 👀 |
20th Mar 2016 4:42am |
