[For Sale] Range Rover 3.6 vogue SE tdv8 Spares repair.... | |
56 plate 3.6 tdv8 vogue SE.
Black with Black
5 previous owners
mileage is circa 145k
Bought last year requiring a replacement engine which was duly supplied and fitted by Any Engines/Engine recon also known as NSV motors in Wolverhampton at a cost of over £5,000, lots of issues with the company and fitting trading standards were involved, whole saga was a nightmare. It had new turbos, pistons crank, injectors checked, Injector pump rebuilt etc replacement EGR valves
12 months warranty was supplied with the engine installation, so it should be under warranty but I am not up for yet another fight with these 2nd rate clowns
The car has covered less likely 3,00 miles since, the engine blew up on Friday night on the M6, so once again it requires a replacement engine, it is knocking so assume that all is lost.
when I had the Range rover in use it drove really well, the interior is clean and very tidy, the brakes gear box and suspension are all good, Heated seats have had replacement blowers so all work as does the Nav and TV setup, gearbox flush and filters, CV joints done, lots of small jobs done to make it a decent vehicle, my plan was to keep it long term, given the money I have spent on it..
well worth repairing if your handy with the spanners, I should repair it and fight the case again with trading standards, but life's too short, time to draw a line under the saga and simply move on.
I am not looking for stupid offers on this and will post pictures latter once its back.
A good opportunity to buy a cheap SE all you need is a second hand engine, if you have one drop me a PM
I am looking for £6500 for it as it sits he car will be in Aberdeen, I have been offered a complete engine for it now at a sensible price.
you would take the replacement engine which is less than 100k on it fit my injectors and new high pressure fuel pump EGR valves and drop it into my Rangie, my Turbo's were new so they might go again, but would need checking. either way it could become a cheap way into a good Range Rover for someone
