Home > Technical (L322) > L322 Trailer Wiring - How it should be done, with pictures !
holidaychicken
I apologise if I seem a little short but I have a 2004 with the Westfalia OEM wiring and ECU fitted with both types of socket and an LED trailer board which all works fine and is plug and play . What am I missing ?
Post #499943 29th Dec 2018 2:43am
p38arover
Australia
"What am I missing ?"
Problems? Laughing Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #500044 30th Dec 2018 5:35am
Danwilderspin
Hi All,
So I have a weird one - the prewired connector is missing pin 8 in the boot which looks like the tail light feed from the lcm? mine is a 2007 supercharged but everything else seems to fit - can I just take a feed from the light behind for the tail input signal?
Thanks Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #585212 25th Feb 2021 3:09pm
Danwilderspin
Looked at the wiring diagrams there are two separate feeds on different pins for the 05+ so that sorted that however I have wiring for the relay on the ore wiring but not on the other side? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #585251 25th Feb 2021 6:37pm
Danwilderspin
Ok doesn’t look like they are needed on the later car all working now thx Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #585256 25th Feb 2021 7:21pm
