![]() | Home > General > underbody protection |
ken Member Since: 22 Aug 2008 Location: On another forum Posts: 936 ![]() ![]() ![]() |
What you let passengers in yours |
Larry Member Since: 03 Dec 2008 Location: East Midlands Posts: 262 ![]() ![]() ![]() |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 ![]() ![]() ![]() |
bit of an update im now in possesion of the G4 underbody guards i.e the front skid plate , the tank guard and the exhaust guard ive spent today fitting the front skid plate and what a b435h it was i had to modify and re weld the corners as i didnt like the way it sat all forward and low down now that ive modified it ive gained an extra 1-2 inch of aproach angle and the skid plate isnt so in your face as you can see the difference between mine and how it looks on a G4 i had to use my extra spare pair of arms and hands to help fit but its getting there heres the pics not great but you get the idea more to come |
Mounty Member Since: 29 Jan 2009 Location: Allschwil Posts: 311 ![]() ![]() |
Hi
hi mounty ive put some pics up im assuming you go off road as for the exhaust guard ill put pics up soon but you need a towbar to fit it also if you are thinking of fitting the tank guard as well i think you need to remove the lower rear suspension arms to fit from what i can see but im having a go this weekend so ill let you know how i get on as for the part numbers i havnt got any but this may help you out as its all the kit that was fitted to a G4
looks good |
yes i tried it for fit and thaught i can make this better as it sat low and stood out like a sore thumb so i cut the ends off refitted without end and then thaught what can i do so spent the day playing about with it the ends are now 2-3'' higher up into the bumper ive still got corner protection as the plate goes to the ends of the bumper corners underneith ive still little bits to finish off but will do the weekend onto no6 Range Rover
How many cm did you cut of? Did you use the same screws to fit it? any other dificulties to fit it?
probly bout 70-80 mm if that helps , and there is normally 4 big bolts that hold it up and bout 10 little ones for the mudguards and stuff mine is a td6 diesel and they fit no probs also the G4 vehicles were all petrol other than the 09 my so sholdnt be any problems as for exhaust guard allow for a full day and be prepared to remove rear suspension arms BUT bere in mind the airbag is in between so im unsure how im going to get round this will find out the weekend if your not 100% confident in removing suspension and doing majer work please DO NOT attempt to do it get a dealer to carry out as it could all end in tears onto no6 Range Rover
Thanks for the pics. I will do it excatly the same. Have you got a pic undernetah from the very front where you cut it?
Any news? Daniel
not much as im in the middle of trying too fit the tank guard, ive only got round too fitting the brkt on the one side as its an absolute pain in the .......... i will fit the other brkt too the other side possibly next week. then ill try for fit and im going to and fit it closer to the tank and just play around with it as the std welding that landrover have done could be better i.e more of it around joints but we will see onto no6 Range Rover
well i spent today fitting the tank guard and just as i thaught it was a pain in the ar£e. but hears a couple of pics
its been a while but hopefully im going to fit my exhaust guard in the next couple of weeks and pics to follow , also ive managed to get hold of a G4 recovery shackle that goes into the 3 1/2 inch reciever of the towbar armature pics to follow |
here you go boys
