Home > Maintenance & Mods (L322) > trying to fit height sensor - torx bolts corroded |
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 |
the sensor is not reusable so either cut/leaver or smash it off
6th Mar 2016 5:56pm |
Ohwhatalad Member Since: 27 Jun 2015 Location: Cambridgeshire, South East Posts: 191 |
hmm not much room to play with in there at all, tried with a hammer and screwdriver and it wasnt budging to be honest
6th Mar 2016 6:00pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1350 |
On bolts like that I normally cut a slot in the head and use a screwdriver, or hammer in a small socket flat bit that is a bit wider than the torx shape V8 or else ... |
6th Mar 2016 8:09pm |
thanks would never of thought to grind in a flat screwdriver head onto them to try get them out, will try that if i get time, thanks again |
6th Mar 2016 8:30pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8195 |
Buy a set of these, Erwin nut removers (other makes available)
6th Mar 2016 8:45pm |
cheers pete, not sure theres room to get a hammer to whack on of those on, but if the first idea doesnt work ive got something else to try at least! |
6th Mar 2016 11:15pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
If you have a hacksaw, or better still, an angle grinder, then simply cut off the heads of the bolts, or grind off the tops of the bolts, and slide off the old sensor, spray with penetrating oil, wait, (cup of tea) and as mentioned, grip the bolts, with mole grips, and gently rock back and forth. Maybe even hit the bolt shaft with a hammer to break the rust seal. - you are going to need to buy new bolts. Can only guess, they are m6 bolts, and are easy to search for say 'm6 torx/socket head bolts 35mm length' on eBay, and for about £3 you will have a handful. Steel, or stainless steel. |
6th Mar 2016 11:31pm |
