![]() | Home > Technical (L405) > Ignition |
RRVSE-2 Member Since: 06 Jun 2015 Location: Kent Posts: 41 ![]() ![]() ![]() |
Just press the radio on button. Keith
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 ![]() ![]() ![]() |
Just press the radio on switch. |
EdJ Member Since: 30 Jan 2015 Location: London Posts: 364 ![]() ![]() |
Is there any way to stop the radio automatically turning off after a short time? 2024 Range Rover P550e AB |
Nigwell Member Since: 01 Jan 2015 Location: Cannock Posts: 91 ![]() ![]() ![]() |
Does do anything on mine |
Nick Ground Member Since: 27 Dec 2011 Location: Dorset Posts: 584 ![]() ![]() ![]() |
A quick momentary press might get missed by the infotainment system. Try being a bit slower. It's a Land Rover after all.
No likey long press either |
Still not worked this out manual no use either. |
Does the radio on/off button work when the ignition is on ? also as its a land rover when l press mine it does take a few seconds for the car to start up the infotainment system. Keith
Booked in at dealership. They don't seem to know what it might be,want it all day. Giving me a loaner bet it's not a range. |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
did you get to the bottom of this? Mine is doing it!
Well no not really started working fine. Still went to dealer checked it out no faults found or updates needed. If your under warranty give Land Rover stafford a call nice and helpful. |
