![]() | Home > Technical (L322) > Folding mirrors - sort of |
steadyaway Member Since: 28 Feb 2015 Location: West Yorkshire Posts: 184 ![]() ![]() ![]() |
Today while parking up I pressed the mirror fold button. Only the drivers side folded in. I lowered the passenger window an got SWMBO to gently pull on the mirror while I tried to fold it again. This time it folded. When I unfolded it, it did it by its self. So I tried to fold it in again and once again it failed but worked with a little persuasion. I would assume that the motor is ok but there is obviously a problem somewhere. Has anyone had a similar issue and can point me in the right direction please? |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2275 ![]() ![]() ![]() |
I had something similar a few months ago there is a reset by double tapping the button that operates them there is a post on here about it but try the double tap i.e. tap the button twice in quick succession hope this helps |
I'll give that a go, nothing to loose. Cheers. |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6416 ![]() ![]() |
Or the microswitch has packed up/got damaged in some way. .
The nearside mirror now folds.........by its self without even pressing the button! When I have my towing mirrors fitted, the air pressure folds the mirror in slightly. I suspect the motor or the gearing. I have watched the YouTube video by powerfuluk explaining how to remove the mirror but I think they did it on a HSE. As mine is the Vogue the trim panel on the inside of the mirror is different as mine has a speaker there. Can anyone tell me if removal is similar or what else I meet to do.
The nearside mirror now folds.........by its self without even pressing the button! When I have my towing mirrors fitted, the air pressure folds the mirror in slightly. I suspect the motor or the gearing. I have watched the YouTube video by powerfuluk explaining how to remove the mirror but I think they did it on a HSE. As mine is the Vogue the trim panel on the inside of the mirror is different as mine has a speaker there. Can anyone tell me if removal is similar or what else I need to do.
Apologies for the double post. I tried to edit the first. |
tiddles1991 Member Since: 10 Jul 2016 Location: Cleethorpes Posts: 32 ![]() ![]() ![]() |
Interesting to hear about the double tap, I shall be trying that on mine! |
