![]() | Home > Technical (L322) > Power steering fluid flush |
kyle h. Member Since: 15 Feb 2016 Location: West Virginia Posts: 23 ![]() ![]() ![]() |
I have a 2006 w/ almost 90k US miles on it. I recently purchased it and while changing the oil, noticed a power steering fluid leak from a copper crush washer near the oil filter (4.2SC), I suppose it was on the pump, but can't remember right now. I tightened the banjo bolt and crossed my fingers until I change the oil again. After I was all cleaned up I noticed the power steering fluid was at the min mark and I can also hear the pump moaning a bit if I turn the wheel while stoped at idle.
smighall Member Since: 15 Jan 2015 Location: West Sussex Posts: 68 ![]() ![]() ![]() |
I've done it and put instructions up on here before. I'll see if i can find it for you. |
From this thread -> http://www.fullfatrr.com/forum/post309180.html#309180
Thanks for the info. The biggest difference I see between your method and the manuals is that you only used 2 liters of fluid. I saw this mentioned somewhere else on the interwebs. Sounds like 4 liters (per the manual) might be overkill.
2 litres was plenty when i did it |
