Home > Technical (L322) > Air sus inactive !!
tonybm730
2003 Range Rover Vogue 4.4 V8 Zermatt Silver
Air sus inactive !!
Hi guys it's happened air suspension inactive I've tried also sorts nothing works and just wondered if anyone close to Wigan area has one of the EAS reset tools for me to try don't mind buying one would just like to make sure it worked I have the dash board warning and the little light on the centre consul were you adjust suspension doesn't work either 😟😟
Post #373394 21st Feb 2016 3:34pm
Most tools are vin specific so best call in at an indy or buy something like an IID tool, which is well worth it if you plan on keeping the FF
Get them to read the faults and tell you them and then reset the system and see what happens... you maybe lucky but don't hold your breath... Pete
Post #373419 21st Feb 2016 5:50pm
Discotigger
+1 to Pete.
You need to get the codes read and check your air struts. for leaks/failures. Also check for water ingress into the rear spare wheel well.
I recently had air suspension problems, caused not just by knackered front air struts, but also by a failed trailer module and a dodgy connection with the abs module. I've got the IID Tool and it was a godsend in helping to diagnose all the problems I had.
All I can add is 'Good Luck' and hope the problem isn't too expensive to sort.
Post #373491 21st Feb 2016 10:25pm
