Home > Technical (L322) > Drivers seat heater doesn't stay on
CY
2002 Range Rover Vogue Td6 Epsom Green
Hi All,
I've just taken the RR on a 1100 mile round trip on business in the UK and a few issues started to surface... Among these, on a very cold morning last week I jumped in and pressed the heated seat button. The lights came on, but after 2-3 seconds they flicked off. I tried again a few times but to no avail. All other heated seats in the car are working fine (so presumably not a fuse).
The iid is simply reading "heated seat fault" with no specifics.
I've searched through here but haven't been able to find anybody provide a cure to this one and I'm not sure where to start. Any thoughts? Embarassed
Many thanks in advance,
Chris 2002 Range Rover Td6 Vogue
Post #373100 19th Feb 2016 11:40am
It's usually a short/break in the element in the seat cushion, the drivers tend to go first as they take more abuse from people sitting on them...
Unfortunately the element is built into the seat cover so the only answer is to buy the whole cover, after tracing and finding if it's the seat cushion (most common failure) or the back rest...
You maybe able to pick up a second hand one on eBay, but no way to tell if it will work...
Could try fitting a generic heating pad under the original cover.... may work....
Good luck Thumbs Up Pete
Post #373104 19th Feb 2016 11:57am
miggit
Are the bases interchangeable...... i.e. sod the passenger Wink would at least prove the point Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #373115 19th Feb 2016 12:37pm
CY
Thanks guys.
Would be good to know if they're interchangeable as it usually just me in the car on the cold mornings when I need them!
If I sourced another seat base, is it possible to retain my leather trim? The leather on mine is absolutely spotless thanks to previous keepers (forum members!) keeping it absolutely immaculate, soft and matt.
Post #373121 19th Feb 2016 1:19pm
Sandyt
Yep should be able to keep cover no probs
Post #373123 19th Feb 2016 1:55pm
The "cover" is the leather bit you sit on.. the element is under the leather, then there are various other layers of stuff... you can't change the leather cover without changing the heating element and vice versa....
You maybe able to get an upholsterer to take it all apart and fix it but I expect that would be more than a new one....
I don't know if the front covers are interchangeable, I doubt it though without some hole somewhere showing.... Pete
Post #373127 19th Feb 2016 2:56pm
Sandyt
Sorry my mistake didn't look at year Embarassed
Post #373131 19th Feb 2016 3:15pm
Don't apologise I've done that loads of times.... Whistle just didn't want the OP buying stuff off ebay to soon.... Thumbs Up Pete
Post #373137 19th Feb 2016 4:03pm
miggit
From what I can make out on line the seat base covers are not handed, so you should be able to swap sides, at least if the problem moves to the passenger side you'll know the cause.... then it will be a case of finding the correct colour cover on fleabay, there are a few peeps who regularly have NOS seat covers Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #373145 19th Feb 2016 4:24pm
Weegie
I got a replacement seat cover from these people at a very reasonable price. Still haven't fitted it Very Happy Might be worth a try.
http://www.lrisolutions.co.uk/ John
GAP iiD BT
Post #373151 19th Feb 2016 4:39pm
All 322 seat base’s are interchangeable from side to side Thumbs Up
Handy to remember when they start to wear too Whistle Thumbs Up
Post #373202 19th Feb 2016 11:44pm
CY
Guys
Many thanks for all this, much appreciated. Sad to hear I can't keep my immaculate leather trim which has been so well maintained over 14 years of life! Sad
Swapping the seats sounds like a good start. How laborious a job is this - I can't find any guides?
Many thanks as ever,
Post #373203 19th Feb 2016 11:48pm
Not a massive job but......... Quite involved never the less...
Best to take the seat out, stick it on a bench and inspect it Thumbs Up Only then will you see whats involved & weather thats within your skill set sir Thumbs Up
Post #373209 20th Feb 2016 12:04am
miggit
Hmmmm, think I might have to play a game of swapsy.... drivers side is getting very soft on the edge and showing it's age, the passenger side has a small nick 6" from the front at the highest point.... just here it can jump out at you Censored Censored Swap them over and the squishy bit goes to the centre console and so does the nick Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #373213 20th Feb 2016 12:11am
Thumbs Up Thumbs Up Thumbs Up
Post #373215 20th Feb 2016 12:15am
