Home > Wheels & Tyres > Driving on a piste /off road on snow |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35287 |
as this is more related to tyres/wheels, i've moved the post here... ... - .- -.
17th Feb 2016 7:19pm |
Bryn Member Since: 19 Jan 2016 Location: Midlands Posts: 13 |
Thank you! |
17th Feb 2016 7:29pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1374 |
LR do an accessory snow traction system part no LR005737 for front wheel use with 20" wheels and chains part no VUJ000020 for rear wheel use on 18" and 19" wheels. I have the chains but as yet have not needed to fit them. You could also consider studded winter tyres, I recall a contributor from Moscow had fitted them. Only Range Rovers since 1988 |
17th Feb 2016 7:40pm |
Thanks CS, I'd seen and considered those. They don't list the 275 width I need, but I'm wondering whether I just gamble and hope they'll work.
17th Feb 2016 8:00pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8512 |
you may have 275/45s fitted but the correct size is 255/50 20 so you may find some suitable tyres in that size.
17th Feb 2016 8:47pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7926 |
Seems like an unusual requirement - are you sure it's a piste - generally they're not compacted enough to take the weight to a car on regular tyres.
18th Feb 2016 7:06am |
Thanks guys,
19th Feb 2016 8:04am |
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1092 |
Not sure which would be worse, gays on trays or a Full fat, suspect it would still be the snow boarders. letters not necessarily in the right order |
19th Feb 2016 11:56am |
Well if I have anything to do with it, there will be both. So double the pain Dixy. |
19th Feb 2016 12:32pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3141 |
@Bryn
19th Feb 2016 4:01pm |
Absolutely, plans change fast but I'm sure there will be something interesting to show! |
19th Feb 2016 4:09pm |
Hi guys, as promised here is it what I needed to source tyres for. This was a project I produced for Jaguar in support of Graham Bell aiming to become the fastest man on skis.
17th Mar 2016 12:52pm |
Looks like fun |
17th Mar 2016 2:00pm |
It looks like a summer mountain road covered in snow and used as a piste in winter. I was imagining an up/down wide piste. That looks like filming was a lot of fun. |
