![]() | Home > Maintenance & Mods (L322) > 2012 L322 front Conversion - only passenger light flickering |
rycymru Member Since: 07 Apr 2015 Location: ky Posts: 5 ![]() ![]() |
2003 Range Rover HSE with 2012 front end conversion. Located in the US.
mick-ne Member Since: 30 Nov 2013 Location: durham Posts: 133 ![]() ![]() ![]() |
Hi, I had a similar problem and it turned out it was the light box I had fitted to the rear light , it was faulty on the side that was flickering. Hope this helps. |
The weather is supposed to warm up at the end of the week and I'll spend the weekend pulling the bumper and grill and switch the lights to make sure the headlight isn't the problem. |
Does it flash both with & without the engine running? |
Yes, the passenger light angel eyes/side light flashes when the engine is on and off and I turn the lights on. There has been a time or 2 when it flashed and then stayed lit up. The driver side might flash 1-2 seconds but then stays on. |
In that case i would definitely rule out the boxes you have wired in by swapping them from side to side |
