Home > Maintenance & Mods (L322) > Caliper painting |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7944 |
Tried searching ?
1st Feb 2016 3:01pm |
ruffy Member Since: 11 Jan 2016 Location: North Yorkshire Posts: 70 |
Thanks Alistair, yes I've had a look at some of the other posts. I couldn't see any references to this supplier, and it wasn't clear for someone with limited mechanical ability (me!) whether removal of any parts is necessary before painting. 1982 SIII 88” diesel
1st Feb 2016 3:08pm |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3818 |
I did this just got the cheapest calliper paints, brake dust remover and stickers of eBay. Took the wheel off and brush painted in situ, obviously not red as that is for folk younger than me.
1st Feb 2016 3:22pm |
Looks good! I can get paint and brake cleaner from Halfords for about 15, might just do that😀 1982 SIII 88” diesel
1st Feb 2016 3:26pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1773 |
Hammerite Smooth. Never failed me yet
1st Feb 2016 3:50pm |
Another good effort! Presumably Hammerite lasts a while too? What sort of brake cleaner did you use, and what type of brush? If I'm going to do this I don't want to it up! 1982 SIII 88” diesel
1st Feb 2016 3:55pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35360 |
this is one of the easiest jobs you can do....clean with a damp cloth, let dry and then paint with any metal/barbecue type paint and use any paintbrush...
1st Feb 2016 4:00pm |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1655 |
.... and the stickers of ebay saying brembo or range rover are actually very good and easy to apply. I brough the white rr wording and it is actually exactly the same as the original size etc. 405 AB exec seats Baltic and Cirrus
1st Feb 2016 4:50pm |
chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 750 |
1st Feb 2016 5:42pm |
Ennoch Member Since: 26 Dec 2015 Location: Scotland Posts: 109 |
For painting rough cast calipers I'd be inclined to use brush on Hammerite smooth but if you're running Brembo's then spray will give a much better finish. I've never really liked Hammerite spray and for calipers have always liked VHT Enamel. It's tough and long lasting if you leave it to dry for 24hrs before using the car. I've used it on quite a few cars that have seen the discs going purple with heat and the paint stands up remarkably well. Standard spray from Halfords is actually not a bad choice if you fancy an odd colour and it's just on something normal like the Range Rover which is highly unlikely to ever see the sort of temperatures required to blister the paint; even when hot the outside of the brake caliper stays pretty cool in the grand scheme of things. |
1st Feb 2016 6:36pm |
87RJD Member Since: 01 Dec 2013 Location: Wokingham Posts: 103 |
Hi
1st Feb 2016 7:01pm |
Thanks for all the responses, I now feel emboldened to give it a go! I will buy some Hammerite Smooth, brake cleaner and a brush and wait for a dry day 1982 SIII 88” diesel
2nd Feb 2016 9:58am |
Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267 |
Have never had the urge to bother with mine but having seen some of these pics I may just have a go ! |
3rd Feb 2016 6:17pm |
EmiratesA380 Member Since: 14 Jan 2015 Location: england Posts: 350 |
6th Feb 2016 3:21pm |
