Home > Technical (L322) > Cornering lights
mjdronfield
The manual on topix says the indicator needs to be on and speed above 18mph and steering wheel turned more than 70 degrees....
Might need another person to help check ! 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #369423 29th Jan 2016 6:13pm
honestly you will defo see them operate from the drivers seat if you do have them ........ ... - .- -.
Post #369436 29th Jan 2016 7:13pm
Blade74
Australia
You definitely don't need to have the blinker on or turn the wheel that far.
Driving along slow and a very small wheel turn will see it shoot out to the left or right.
You would know if your car has it pretty easily.
Post #369472 29th Jan 2016 9:53pm
comports
Wot Blade said Thumbs Up Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #369474 29th Jan 2016 10:04pm
I guess he doesn’t have it Whistle
Post #369490 30th Jan 2016 12:04am
dolph34
Just to ask , my 2007 has these lights but I would like them LED Does anyone know what I a I would need ?
Thanks in advance 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #372510 15th Feb 2016 5:39pm
Phil303
United Kingdom 2007 Range Rover Vogue SE 4.4 V8 Buckingham Blue
I've got them on my 2007 as well. They seem to work when stationary too; a turn of the wheel engages them.
Post #372513 15th Feb 2016 5:54pm
Spannerman
New Zealand 2008 Range Rover Vogue 4.4 V8 Java Black
My 2008 Vogue (Jap import) has cornering lights, doesn't require indicators to be used to illuminate them. Shocked
Post #374040 24th Feb 2016 11:59pm
NDT
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Quick question - are all the headlight assemblies the same? Ie just with bulbs in the cornering bit when cornering lights are fitted?
I can’t see bulbs in my cornering section - but I can see holes where bulbs should be.
Post #704520 15th Nov 2024 4:13pm
