Home > In Car Electronics (L322) > Frozen sat nav
Mark Everett
United Kingdom 2016 Range Rover Autobiography SDV8 Corris Grey
Frozen sat nav
Guys the Battery died in my 2008 tdv8 i let it stand for 5 mins with key out then changed battery with no problems except that the sat nav has frozen and you cant get past the first screen everything else works phone blue tooth cd ext if i disconnect the battery it will work then when you start engine screen goes blank for a split second then comes back on but sat nav does not work? (frozen) i cant even eject disc when it is like this i am starting to lean towards sat nav unit being u/s,What do you guys think?
Post #368699 24th Jan 2016 4:38pm
this might help, from our wiki,
http://www.fullfatrr.com/forum/post248527.html#248527 ... - .- -.
Post #368713 24th Jan 2016 6:03pm
Mark Everett
Frozen sat nav
Ok i will try that but everything still works except sat nav frozen
Post #368715 24th Jan 2016 6:09pm
