Home > General > It's time!!
chefkenmore
Scotland 2014 Range Rover Vogue SE SDV8 Loire Blue
It's time!!
Legal for another year..............................
Woohoo Thumbs Up 2014 vogue se
Post #368429 22nd Jan 2016 4:03pm
that was lucky.... Whistle
any major advisories? There is nothing that can't be fixed with a hammer😜😜
Post #368432 22nd Jan 2016 4:07pm
chefkenmore
Mot
Nothing!!!!
Just said it could do with a couple of new brake pipes at some point! MOT tester is my mate and does all my maintenance!
Still put it through its paces tho! Thumbs Up 2014 vogue se
Post #368433 22nd Jan 2016 4:11pm
Mr Tee
A pass is always a welcome result. Where abouts do you chef?
Post #368435 22nd Jan 2016 4:13pm
"MOT tester is my mate and does all my maintenance!"
I like that. Wink Whistle Thumbs Up
Post #368436 22nd Jan 2016 4:13pm
chefkenmore
The clue is in the avatar!
Fearnan, Loch Tay
Kenmore
Aberfeldy 2014 vogue se
Post #368439 22nd Jan 2016 4:20pm
Sql
Poland 2007 Range Rover Vogue TDV8 Buckingham Blue
Is it really that hard to get a car through MOT in UK? I seem to see many threads where you guys tend to be happy as if you won a lottery after your cars pass. 07 3.6 TDV8 Vogue
Buckingham Blue / Sand / Piano
Post #368866 25th Jan 2016 6:08pm
For a modern well maintained car ..... No.
For older cars cars which may have slipped in maintenance slightly then it will highlight any weak points and if they are beyond an arbitary tolerance then they will fail the car, so bushes etc, are usually things on older cars which will cause a fail. My Skoda had an issue with a bush this year, which was marginal. There is nothing that can't be fixed with a hammer😜😜
Post #368883 25th Jan 2016 7:32pm
nwmgc
United Kingdom 2015 Range Rover Vogue SE SDV8 Corris Grey
Mine's just back after 6 days at the stealer. Had to be submitted three times - including a fail on the handbrake, which was amusing as the stealer had put on new rear brake discs. Rolling Eyes
Post #368971 26th Jan 2016 3:05pm
