![]() | Home > Technical (L322) > TPMS not on a 2010MY ? |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1401 ![]() ![]() ![]() |
I don't have it (2012) so I would have thought 2010 need not either. Only Range Rovers since 1988 |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8001 ![]() ![]() ![]() |
I have an L405 without TPMS |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
My 2010 doesn't have it. |
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1055 ![]() ![]() ![]() |
Nor mine |
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398 ![]() ![]() ![]() |
Think it was an optional extra, so may not have it. My 12my doesn't have it either.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6766 ![]() ![]() ![]() |
Total waste of time having it, I have and turned it off. Got - 2017 SDV8 Autobiography in Loire Blue
I have a 2011 brochure and didn't see any mention of TPMS in the standard specs, even the early 405 brochure had TPMS as a £395 extra for all models. Only Range Rovers since 1988 |
ksskaret Member Since: 27 Oct 2013 Location: Tromsø Posts: 73 ![]() ![]() ![]() |
Why dont you register here http://topix.landrover.jlrext.com/topix/ve...X.prs72696
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Not standard, the wheels have possibly been swapped for nicer ones off as said.
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1664 ![]() ![]() ![]() |
Dec 2010 does not have it. SWMBO 6 series has it and its total pants. waste of time regular incorrect warnings etc. 405 AB exec seats Baltic and Cirrus
http://www.amazon.co.uk/gp/aw/d/B008OUOMQ6...ref=plSrch
Our last one had it and current one doesn't have it; and wheels are factory spec. Fine about not having it. As northern monkey says, weekly tyre pressure checks will probably serve you better than waiting for a computer to tell you something has gone wrong... And weekly checks also keep you down and around the business areas of the car so you can check up close that all is as it should be (tyre condition/ wheel condition/ bodywork etc).
