![]() | Home > Maintenance & Mods (L405) > Boot liners and dog guards! |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8001 ![]() ![]() ![]() |
I don't know of a divider that doesn't rely on the upright between the headrests to keep it in place.
modbarra Member Since: 28 Mar 2009 Location: northampton Posts: 237 ![]() ![]() ![]() |
When we had our mini schn's, we used the crate but I put small lengths of clear tubing on the parts that touched causing the rattles.. Just cut short piece, slice it along length then slide over... I think it wa either washer or fuel tube from halfords |
pjb Member Since: 15 Feb 2010 Location: Sunny Oxon Posts: 244 ![]() ![]() |
I use a TransK9 dog crate
sagalout Member Since: 30 Dec 2015 Location: Harrogate Posts: 22 ![]() ![]() |
Thanks for the replies - might take a look at the transK9...but also the rubber hose idea might work on the existing cage to stop it rattling! |
Hatchbag for the liner. Comprehensive coverage, easy to fit and not too costly. |
EdJ Member Since: 30 Jan 2015 Location: London Posts: 364 ![]() ![]() |
I've got the divider which is a quality piece of kit, and also very useful. However, when you combine it with the official Land Rover heavy duty boot mat, it doesn't really fit properly for some reason. It's almost as if the boot mat is just a little too big. 2024 Range Rover P550e AB |
Badger Member Since: 02 Jan 2011 Location: Bucks Posts: 170 ![]() ![]() ![]() |
I have the LR rubber boot liner which is very grippy, and use a Lintran dog box which fits perfectly, with no rattles.
martinf Member Since: 26 Dec 2014 Location: sussex Posts: 256 ![]() ![]() ![]() |
I have the same system, LR boot liner and Lintran box. I am very pleased with it.
Plus worth having one of these:
