Home > Technical (L322) > Well that went well... not! |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1407 |
the exhaust is not as hard as you think to drop off the car. Just support it as best you can when undoing the nuts.
4th Nov 2010 9:59pm |
SteveMFr Site Sponsor Member Since: 22 Nov 2009 Location: Strasbourg, France Posts: 1641 |
If the thread is not too , you can get a spark plug thread chaser and redo in situ. You'd need one that can be turned in the middle with an ordinary wrench (spanner ).
4th Nov 2010 10:12pm |
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 |
I know the feeling, i turn an oil change into hard job. Last year i rounded off a sump bolt, then broke an easy out on it leaving that stuck in the bolt...... Had to call a mate in the end, he welded a bar to it and it shifted.
4th Nov 2010 10:31pm |
red_slr Member Since: 06 Oct 2010 Location: Manchester Posts: 42 |
Sealey do a cat thread chaser £4.00... only snag 4 day wait!
5th Nov 2010 11:40am |
Exhaust is back on the car now, just about to re-fit the new O2 sensors and see what happens.
5th Nov 2010 12:03pm |
Fault codes have gone which is good.
5th Nov 2010 12:58pm |
