Home > Technical (L322) > Auto Dim Permanently On
Phi.
United Kingdom 2010 Range Rover Vogue SE TDV8 Baltic Blue
Hi I have searched to resolve this problem but have been unable to find the answer.
Can someone advise me how to either disable the auto dim mirrors or fix them.
With the mirrors being dark all the time, night vision is somewhat difficult.
Vehicle L322 Range Rover 2010.
Cheers.
Post #365749 6th Jan 2016 8:36pm
IanT599
Is it still dimmed when the car is in reverse.
Post #365755 6th Jan 2016 9:16pm
Zirconblue
Driving everywhere in reverse is a pain though. Laughing (no i'm not being serious - and i understand why you're asking)
Post #365792 7th Jan 2016 1:34am
RP123
Scotland 2006 Range Rover HSE Td6 Bonatti Grey
Hi Phi,
Have you tried a battery disconnect? - Bit of a long shot, but you know what our loveley FF's electrics are like!!
Cheers
Simon
Post #365825 7th Jan 2016 9:51am
Phi.
The mirrors clear when the car is put in reverse.
If I disconnect the battery will this cause any other problem? With such complex electrics I am reluctant to tinker and cause more headaches.
I will try driving in reverse today though this does gives me a stiff neck! ( Top Tip)
Post #365828 7th Jan 2016 10:04am
RP123
Phi,
There is a comprehensive instruction in the Wik on the battery disconecti.
if you follow the process it should be fine. Just remember to turn the steering wheel lock to lock afterwards.
I have to do it occasionally when one of the electrical brains has a fart. (radio stuck on for example) If you do a search the battery disconect process is often recomended for strange electrical grmenlins.
cheers
Simon
Post #365928 7th Jan 2016 7:42pm
Phi.
Many thanks Simon I will have a go this weekend and post the result.
Cheers Phil.
Post #365931 7th Jan 2016 7:59pm
Phi.
Seemed to have done the trick, many thanks.
Post #371658 10th Feb 2016 3:26pm
