Home > In Car Electronics (L405) > Where to put sat nav? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35403 |
air vent mount? stays off the front screen then.. ... - .- -.
4th Jan 2016 9:58pm |
Badger Member Since: 02 Jan 2011 Location: Bucks Posts: 170 |
Yes, and brings it forward so more accessible.
4th Jan 2016 10:01pm |
you should be able to close that particular vent [on the L322 you can]
4th Jan 2016 10:07pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3978 |
Can you not get Brodit mounts for your car and sat nav? |
4th Jan 2016 10:16pm |
bgennette Member Since: 13 Jan 2013 Location: Newcastle Posts: 79 |
I built mine in 5 parts -
5th Jan 2016 4:03am |
That's really helpful thanks, I will share with the Dealer as they will fit it before collection. I have always used a Road Angel speed trap detector (fitted to rt of steering wheel), so this will replace that plus give me proper nav |
5th Jan 2016 7:28pm |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 |
In passing, just wondering what issues you found with the LR SatNav ? The only think it lacked for me on the L405 was the speed cameras etc which I have now added via the 'My POIs' option in the menu, but this never really bothered me on my old L322 satnav, just a nice to have. Steve
6th Jan 2016 12:17pm |
Phew, where do I start?....
6th Jan 2016 9:23pm |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2578 |
They have - InControl Touch Pro is coming. |
7th Jan 2016 12:21pm |
sagalout Member Since: 30 Dec 2015 Location: Harrogate Posts: 22 |
I'd agree about the wierd routing. My car seems to have a fascination with Manchester and tries to take me via it at the strangest times. Eg Northampton to Leeds, which is straight up the M1, it tried to go via M6 and M62 which wasx80 miles longer. Birmingham NEC to Harrogate and it also wanted to go via Manchester!
9th Jan 2016 8:45am |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3835 |
I only use mine infrequently and always have a trusty maps as well in fact I echo the points about Manchester, living nearby. I think someone needs to write a play about a sales rep having a spoken affair with his/her sat nav - can't be me though because sometimes as it suggest routes SWMBO says I mutter "you must be joking" Geoff |
9th Jan 2016 12:40pm |
Wow Badger, wasn't expecting such a big list , I'll now check mine next time I set a route , as I live near Manchester , I probably wouldn't notice the 'via Manchester' issue but I'll compare it with my Garmin next time to see if I am taking the most direct route.
9th Jan 2016 4:13pm |
