Home > General > Why did I buy it!!!! British engineering!!
silverbackmike
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
Funny you should say that. I did indeed read up on ml's prior to purchase. However I must have owned the only completely trouble free example in the world, apart from the usual requirement to replace the k25 relay and replace the injector seals that was it. A great old bus...
Saying that the range rover failing was my fault ☺
I may need to change the thermostat though as the temperature gauge is up and down.... 2007 FFRR TdV8 - Java black
1995 TVR Chimaera - Starfire blue
2009 Fiat 500 Abarth Essesse
Post #366512 11th Jan 2016 1:45pm
