Home > In Car Electronics (L322) > Backup camera problem
Ericl123
United States 2010 Range Rover Supercharged 5.0 SC V8 Atacama Sand
I have a 2010 RR. The backup camera is not working. When I go in reverse the camera image is now black and white, instead of color also the image is reversed. So if an object behind the car is on the left, the camera shows it on the right.
I brought the truck in for service and the dealer said the camera needs to be replaced for $750. Shocked
That seems very expensive.
Has this camera problem happened to any one else?
Post #362461 16th Dec 2015 12:56pm
That does seem expensive.
I believe the part number is LR012678 - but worth double checking.
Worth checking eBay - there's one here for $250 Whistle
Depends whether you are sure it's the camera & are competent enough to replace it yourself.
Post #362462 16th Dec 2015 1:06pm
Ericl123
Thank you for the link to the camera on eBay. This might be a good option for me.
Do it myself, I don't think so Rolling with laughter but I have a local shop that can do it.
Thanks again Thumbs Up
Post #362468 16th Dec 2015 1:41pm
Yes it happens all the time on 09>my’s Rolling Eyes
Does your car have the camera package? i.e. vision assist? If so, the camera is a lot more expensive than the fixed one!
Post #362497 16th Dec 2015 4:01pm
The camera Alistair has highlighted above does NOT show the plug on the rear so I’m unsure which one it is...
Send Dan @ Duckworths a PM with your VIN and he will quote you Thumbs Up
Post #362498 16th Dec 2015 4:04pm
Ericl123
Thanks, I'll send Dan a message right away!
Post #362582 17th Dec 2015 8:00am
