Home > Technical (L322) > TDV8 won't start and the solution! |
nobbyclark Member Since: 16 Sep 2014 Location: Cumbria Posts: 131 |
I fitted a new battery a few months after purchase and all was well for a year, but my non-starting problems have started again recently. Since this appears to be a common problem, I would have thought that LR would have designed the multifarious systems to eventually shut down apart from the bare minimum such as the alarm and remote sensors. |
11th Dec 2015 4:49pm |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1655 |
Good advice Dijit. A CTek charger is ideal for trickle charging especially with the winter approaching It does have battery recondition function too but not sure this would heal a fubarred unit. Worth investing in a CTek5.0. 405 AB exec seats Baltic and Cirrus
11th Dec 2015 6:42pm |
Bryan N Member Since: 01 Jan 2014 Location: Cambridge Posts: 68 |
Unnecessary quote removed
11th Dec 2015 9:11pm |
Dijit Member Since: 09 Jul 2012 Location: Glasgow Posts: 165 |
Any idea of the years these vins cover?
12th Dec 2015 2:13am |
Yes - 2010 MY 3.6 litre TDV8 within the quoted VIN range. |
12th Dec 2015 10:39am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
Check if your battery has AGM stamped on it! If it has, it will have had the recall as they replace batteries during the Service Action from old type Lead Acid to Advanced Glass Mat |
12th Dec 2015 10:47am |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2655 |
Craig, my car is a 2010MY, battery flat as a pancake this morning, my chassis number ends 307210, do I just contact main dealer to action the above? I take it they only action after requested by an owner? |
3rd Jan 2016 10:49am |
